power lock control module location
Hi, about to install a keyless entry receiver for the 1988 Camry All-trac. My repair manual shows the wiring and everything nicely, but where is the actual door lock control module itself? Its labeled on the diagram as a "relay" but of course like most "relays" in automotive circuit diagrams its clearly somewhat more complicated than just a simple relay. All the same, where is this thing located? Is it actually the relay around the fuse panel area or is that guy the relay to supply power to the whole thing and the control module is somewhere else?
