Originally Posted by Rock79
I changed the coil already. It helped the starting alot. After I did that I had to move the dist. to make it run right as far as acceleration so Im probably off time again right?Beacause thats how it ran when I got it Before it failed timing at smog check.And before I did anything at all to the car. Unless a bad coil would mess with timing.??
Am I wrong in thinking a timing issue would be acting up all the time in the same way, or do they come and go and vary in severity ?
thanks white,dem...
Im going to do the cap rotor wires and plugs tonight Ill report back.I hope it helps, but I dont think it will.
any ideas on the radio thing????
A new coil will not mess with timing at all. Make sure it is set correctly (jumper the T and E1 connections, use a timing light, run between 10* and 12*).
If the motor doesn't feel good then, check your mechanical timing - make sure the timing belt isn't off 1 tooth, etc.
Replacing other ignition components is also a good idea (like you are planning)
You will probably just have to put a fuse in and see what happens with the radio. You will probably have to open the dash behind the radio and look for hacked wiring, etc. if the fuse does blow. If it has an aftermarket radio, that would be suspect, as would the cigarette lighter.
-Charlie
