Originally Posted by sam333
Bad EGR is the #1 cause, are your sure its really working?
What were other emmision #s ? If the cat was bad you should have high HC/CO too.
How many miles on the cat ? 150000 miles is about the limit before you start having cat problems, on a good running engine ( no oil /coolent burning),
Like what atobe said, high combustion temps ( coolent temps .timing(overly retarded) EGR ,overly lean mixture, exhaust back pressure to high.
Hey Sam,
I'm not positive about the EGR, to be honest I'll have to doublecheck that once I figure out what size wrench I need to get the pipe off. The biggest I have is 18mm... Hoping the CD-ROM shop manual I purchased on Ebay has the EGR test in it somewhere, I believe it does.
here are both sets of emission test numbers:
1st test
1st Test
High speed
HC (PPM) Standard = 174, current = 14 = PASS
CO (%) Standard = 1.12, current = .19 = PASS
CO2 (%) Standard = blank, current = 14.8
O2 (%) Standard = blank, current = .2
NOx (PPM) Standard = 1258, current = 1972 = FAIL
Dilution (%) Standard = >6, current = 15
Low speed
HC (PPM) Standard = 180, current = 17 = PASS
CO (%) Standard = 1.01, current = .18 = PASS
CO2 (%) Standard = blank, current = 14.7
NOx (PPM) Standard = 1378, current = 1842 = FAIL
Dilution (%) Standard = >6, current = 14.9
2nd Test after the big time tune up
2nd Test
High speed
HC (PPM) Standard = 174, current = 15 = PASS
CO (%) Standard = 1.12, current = .45 = PASS
O2 (%) Standard = blank, current = 0.0
NOx (PPM) Standard = 1258, current = 1769 = FAIL
Dilution (%) Standard = >6, current = 15.1
Low speed
HC (PPM) Standard = 180, current = 16 = PASS
CO (%) Standard = 1.01, current = .41 = PASS
NOx (PPM) Standard = 1378, current = 1780 = FAIL
If the timing was off, wouldn't I notice that in the performance? I'm not noticing any of the typical symptoms of a timing issue and the temp gauge is never going above halfway.
Appreciate the assistance.
