taillights/breaklights 88 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2011, 02:01 AM   #1 (permalink)
View Rock79's Photo Gallery
2nd Generation taillights/breaklights 88 camry
When my headlights are on, my outside tail lights shut off when I step on the brake pedal but the brake lights on the trunk and the small one in the window work fine.The outer tail lights work fine without headlights on.
Got a couple good (I think,no burns on circuit board) tail light fail sensors for the trunk, but then the outer ones would not turn on at all with either of them installed!!? They only work with the BAD sensor (obvious burn on the circuit board) plugged in.
I dont get it.
Rock79 is offline   Reply With Quote
Old 05-25-2011, 06:04 PM   #2 (permalink)
Cruisin in the Gen2 Cam
90camry5speed's Avatar
View 90camry5speed's Photo Gallery
I dont get it.
I had the same problem on mine , I fixed it by cleaning the terminals with a wire brush. and the is a lubricant for the connections..
1990 Toyota Camry 5speed 3sfe (base model)
1963 Ford Galaxie 500 2dr sedan -289 3spd
1972 Ford Maverick 2Dr 200 I6 auto with A/C
2010 Toyota Prius ( base model )
90camry5speed is offline   Reply With Quote
Old 05-25-2011, 11:35 PM   #3 (permalink)
Thanks,Ill try that. I just dont get why they would work fine when the headlights are off if its dirty connections.
Old 05-28-2011, 01:55 PM   #4 (permalink)
2nd Generation
Sounds good just let me know if that solved the problem.
Old 05-31-2011, 01:55 AM   #5 (permalink)
Nothings working.Any ideas?? Brake switch?
Old 05-31-2011, 11:31 AM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Now its time to check the fuses. You can also easily test the brake light switch - it is at the top of the brake pedal (it acts as the 'stop' for the top of the pedal travel). Check for power on the chassis plug (on one side) and check that there is continuity between the two pins when the brake pedal is depressed.
I would guess still that there is a wiring problem in the trunk. Check for torn/worn/frayed wires around the trunk hinge and around/near the outer tail lights.
-Charlie
Old 05-31-2011, 06:23 PM   #7 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
I had this problem. For me turned out to be the ground wire next to the tail light bulb. When I hit the brakes the tail light would go out.
66conv6 is offline   Reply With Quote
