Timing belts generally go out at or near idle. In this car, they are supposed to be changed every 60k miles - so unless you are comfortable getting left on the side of the road, change it that often. At least its a non-interferance engine, so there should be no damage if the belt breaks.
As for the rest of it - the harder you run the engine, generally the shorter its life. Spinning to 5k rpm a few times every drive (as long as it is warmed up first!!!) is not really a bad thing though. High RPM wears out things that are more expensive to fix than the timing belt - bearings, pistons+rings and valvetrain.
Keep up on the maintenance and you'll be fine.
-Charlie
