1991 DX Shuts off When Stopped? - electrical issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2011, 11:07 PM   #1 (permalink)
Gen2 King
91 Camry's Avatar
Gameroom cash: $161755
View 91 Camry's Photo Gallery
2nd Generation 1991 DX Shuts off When Stopped? - electrical issue
Hey guys i have a problem i need some input on...
When i bring the car to a stop at a redlight, ill be sitting there and all of a sudden the car shuts off, i loose my radio stations, and my clock resets.
Its almost as if someone is disconnecting the battery and it only happens when the car is stopped and idling.
The terminals are tight on the post, i check.
Any other suggestions to things i could check that could solve this problem?
Thanks,
Mike
~~~~GEN-2 Camry~~~~
Running the Streets Since 1986
91 Camry is offline   Reply With Quote
Old 05-27-2011, 01:38 AM   #2 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Check all your power and ground connections. Connections can be tight ,but corroded underneath . Start with the battery and remove the positive and negative leads from the posts and then clean .Move your way down the line ( buy a manual so you how many and where the major connections are). Check where the battery cable goes into the main fuse block, fusable links and main fuses for corrosion/ high resistance. Test your alternator and connections also. Do you have a multimeter?
sam333 is offline   Reply With Quote
Old 05-27-2011, 08:58 AM   #3 (permalink)
Gen2 King
91 Camry's Avatar
yea i have a multimeter and an alternator checker...think that could be it? all connections seem fine
~~~~GEN-2 Camry~~~~
