Moisture in the cylinders - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2011, 09:14 PM   #1 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
it’s NOT a bad head gasket.
I just reinstalled the engine and I think I might possibly have mixed up the two hoses connected on the drivers’ underside of the intake manifold. One appears to vent the crank case and I can’t see clearly where the second hose connects? I am also wondering if I may have mixed up one these hoses with the hose needing to go to the charcoal canister ?
I am wondering if any of these possibilities may be introducing moisture into the intake system. Or do I need to be checking elsewhere.
Sturdavj is offline   Reply With Quote
Old 05-29-2011, 05:33 PM   #2 (permalink)
I located part of my problem.
I crossed up the hoses that run between the ISC valve and the water by-pass pipe and the hose connected to the rigid pipe/tube on the outside rear of the air plenum.
This as far as I got for now, I have to go to a soccer match….
Later, I will need to figure out what hose feeds the rigid tube ….
