What resistance do you get if you put the probe leads together? What about if you connect them together using one pin on the coil (if possible)? You will probably find that the extra resistance you are seeing is just part of your test setup, not the coil. It is very hard to test resistances <2ohms or so...
If there are hairline cracks in the coil, it needs to be replaced. A new one is probably fine, but there are no guarantees.
-Charlie
