Separate drain/fill is only for the auto. The FWD manual uses a single drain bolt as a drain and a single bolt as a fill.
Use Dexron III ATF (yes, ATF for the 4-cylinder manual trans) and fill fill until fluid comes out the fill hole when the car is on level ground. As long as you can remove the fill and drain plugs (remove the fill first, just in case!), it is a very easy project.
-Charlie
