You should be able to get a complete replacement (remanufactured, lifetime warranty) for under $100 for either side. Don't get a new one at the dealer!
For the driver's side, all you need is any FWD 4-cyiinder manual axle ('87-'91). Yes, there are different versions, but the geometry and the splines, etc. are the same between all versions and they can be swapped.
For the passenger side, it is similar - you can do a complete replacement with a different style as long as it is for a FWD 5-speed.
For reference, my '90 Japan build 5-speed and my '90 US built 5-speed both had the same style axles.
For the carrier bearing behind the motor, there should be a c-clip that holds the axle into the transmission, along with a bolt with a rubber nub on the end that keeps the outer bearing race from spinning. (you can replace the rubber nub that is probably gone with a very short piece of vacuum tube or whatever)
-Charlie
