radio issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2011, 08:52 PM   #1 (permalink)
ecl
View ecl's Photo Gallery
radio issues
I found a radio at the junk yard today while looking for a few other things. Later while trying to put it in I ran into some issues. I got my stock radio out that was having issues, and started to splice the wires. Now when I normally do radios the red wire is power so I hook up the power ground and remote to see if the radio actually works ans nothing happens. So I tried another radio and the same thing happens, I then test the wires for power and come to find out its a gray wire for power. I then try every thing again and still nothing, so then I try the stock radio again and nothing with that one either. Im completely lost at what to do, any ideas?
ecl is offline   Reply With Quote
Old 06-05-2011, 01:44 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
do you know what red wire is for ? check your radio fuse on the kick panel
Old 06-05-2011, 08:41 AM   #3 (permalink)
View nopain00's Photo Gallery
FYI grey provides +12 when the key is at ACC or ON. Blue w/ yellow stripe provides constant +12. Brown is ground. Red goes to RRH speaker.
Are you sure you're still getting voltage to both grey and blue-yellow when the key is in, and that your ground is good? Try powering the radios directly from a power source that you know is good. If they don't work that way, then the problem is with the radio. Otherwise, check the fuses as atobe said.
nopain00 is offline   Reply With Quote
