Aloha Doctor J and Corolla 71-
Thank you for your replies. Corolla you are probably right, not worth getting a part from the salvage yard as it will most likely have the same problem. So, I will do Doctor J's fix. My concern is taking off trim and breaking something but it sounds like hopefully a phillips screwdriver should do the trick to getting the dash board pieces off so I can get at that circuit board with the lights on it.
From what I understand Doctor J, from the 2 yellow dots you marked on the board (one on each side), that shows the rivet where the wire needs to go through and the path it should follow on both sides, then just solder this wire on both sides making sure the fix stays with the path-circuit track if you want to call it.
I am curious what gauge of wiring did you use? I was curious if a small gauge of solid core wiring would work but maybe you like the stranded wire because it can soak up more solder and thus make a better connection-bond to the circuit board.
Thanks again for your help on this.
Mahalo,
Glen
Originally Posted by Doctor J
As far as I know 90 & 91 should work; however if it is same design it may give you the same problem.
