Start/Stopping - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 01:06 PM   #1 (permalink)
View franxtoy's Photo Gallery
Exclamation Start/Stopping
Hello, I have this 1991 Toyota Camry Wagon 4 cyl w/ 190,000 miles. The problem; it now starts but then DIES right away. So we removed the injectors, cleaned and soaked them, re-installed but same thing. Replaced fuel filter but no luck. If I jump the cold start injector it will stay running (low Idle RPMs - as soon as I try to accelerate engine it wants to die). Also kept it running with carb cleaner through the main intake plenum with the air box disconnected.
ANY ideas out there. I'm a first time poster. Tahnk you in advance.
franxtoy is offline   Reply With Quote
Old 06-07-2011, 02:47 PM   #2 (permalink)
oh and it's getting a OBD 1 reading = 43
Old 06-07-2011, 04:40 PM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Is it getting enough spark?
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 06-07-2011, 05:26 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906227
iTrader Score: 59 reviews
I moved your thread to the appropriate forum. Maybe someone here familar with Gen 2's will be able to help you solve your problem.
to TN
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
The Following User Says Thank You to eyeball96 For This Useful Post:
franxtoy (06-07-2011)
Old 06-07-2011, 05:42 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Code 43 is for the starter signal to the ECU... I don't think that is related to the problem at the moment.
Try placing a jumper wire between the Fp and B+ connections on the diagnostics port in the engine bay. If the motor stays running, you have a defective AFM (air flow meter, on top of the airbox).
Did somebody recently remove the airbox lid (and unplug the wiring harness)? If done incorrectly, it can damage the AFM internals and cause the problem you are describing. The car should not run with the air intake tube remove also (a sealed intake from the AFM to the throttle body is required for proper running of the motor).
-Charlie
PS. I have 2 extra known good working AFMs...
Old 06-07-2011, 08:52 PM   #6 (permalink)
yes it's getting spark as far as I can tell
Old 06-08-2011, 10:46 AM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Also check the ground wire connection below the driver side headlight
Doctor J is offline   Reply With Quote
Old 06-09-2011, 01:14 PM   #8 (permalink)
View matdbom's Photo Gallery
i had a 91 accord that would start and then die right away because of a bad electronic ignition switch. but since you are able to keep it idling i dont know if that could be your problem. good luck
matdbom is offline   Reply With Quote
Tags
1991 camry, wont fire, wont stay running
