Is it necessary to prime the oil pump with grease when replacing oil pump seals? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2011, 05:58 AM   #1 (permalink)
View holmesnmanny's Photo Gallery
Is this necessary? I'd like to know for sure or can I simply crank the engine over with the EFI fuse pulled until the oil light goes off.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 06-16-2011, 04:23 AM   #2 (permalink)
Seriously, anyone ? Or can I just spray it a good bit with some oil and remove the EFI fuse and crank it until the oil light goes off ?
Old 06-16-2011, 09:06 AM   #3 (permalink)
View JOET/CAMRY's Photo Gallery
I had the oil pump out on my 1989 Camry 4 cyl. when changing out the timing belt, water pump, camshaft seal, crankshaft seal, oil pump shaft seal, oil pump spaghetti seal. I lightly greased the parts where there was metal to metal contact. Helps protect the parts until oil reaches them when starting the engine. Not sure if it was the proper way to do it but it worked for me.
JOET/CAMRY is offline   Reply With Quote
Old 06-16-2011, 11:50 AM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
On the engines I have built (non-Toyota) I have done just that... just crank without firing the motor (fuse removed, crank trigger removed, coil unplugged, etc) until the top end of the motor gets oil (along with the turbo on my Subaru). It should be fine that way. I do like the idea of lightly greasing/lubing the metal-to-metal contact areas though.
-Charlie
Old 06-20-2011, 08:20 PM   #5 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Back in the day.... we would use STP (not a lot of product, in those back & white TV days... as my kids refer to them) to assemble fresh parts. It stayed put fairly well, util engine was cranked over (w/no coil wire in place)
Today, I would check out Lucas oil products,
But I am sure there are equal brands as well
Sturdavj is offline   Reply With Quote
