re: Alloy Rims
Aloha Folks-
My 1989 came with the usual steel Toyota Rims, 5 bolt pattern. Well, at the junk yard I found a 1991 Camry that had the alloy 5 bolt pattern rims and at 19.00/ea I thought I would get them, plus my sweet to get them off!
My question is I have been researching and some say they are aluminum and others say alloy. I ask because I think they are alloy and can be painted, as I see some nicks, a couple of "paint-flakes" I believe that came off, close to the lip area.
If these can be painted would you suggest just a lite sanding first, then would you prime or not? If so, what kind of primer?
Lastly, at Kragen I saw the brand Dupli-Color I believe, and they sell wheel paint and wheel clear protective coating. Is this the way to go or are there other paints, brands you would suggest?
Thanks so much.
Mahalo
PS: for those little nicks, rash marks on the lip area is it all right to use say a dremel tool and stone to smooth them out a little?
