What is this part ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2011, 02:07 AM   #1 (permalink)
View holmesnmanny's Photo Gallery
What is this part ?
http://www.utoyot8.com/FullImage.asp...8-++++%292VZFE
The top left corner 17650 VSV(vacuum switching valve). Mine was originally broke so I previously pulled one from pick n pull and put it on but I never did find out what it does. It is attached via a scew to the RH bank valve cover.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 06-14-2011, 09:19 AM   #2 (permalink)
View nopain00's Photo Gallery
I believe that's the fuel pressure VSV. It raises the fuel pressure during a hot restart. Usually the fuel pressure is low when the vacuum is high (like at idle), and high when the vacuum is low (like at WOT).
During a hot restart, the ECU supplies voltage to the VSV, which vents the vacuum to the atmosphere, which "fools" the fuel regulator into supplying higher pressure.
With all this said, you can have a hot restart just fine without this valve operating in most conditions, though the starts may take a tad bit longer.
nopain00 is offline   Reply With Quote
