engine oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2011, 06:34 AM   #1 (permalink)
View camry_rocks's Photo Gallery
Australia engine oil
Hi guys i have a 1991 camry sv21 with 351,000 just wondering what kind oil i should run as i think i have some leaks and i want to get it passed the roadworthy can anyone help?
camry_rocks is offline   Reply With Quote
Old 06-18-2011, 11:25 PM   #2 (permalink)
Gameroom cash: $129205
View blu_91_cam's Photo Gallery
I'm currently running maxlife 10w-40 with good results. I notice a slight increase in power and fuel economy with 10w40 compared to 10w30 and with your mileage I say a little thicker oil would help with the leaks...
blu_91_cam is offline   Reply With Quote
Old 06-19-2011, 12:09 AM   #3 (permalink)
View sfjen's Photo Gallery
re: oil
Aloha Camry_Rocks and blu_91-
I too was wondering about this. Folks in my area just say to use "castrol" and whatever oem would be. So, does the 10w40 offer a little more protection or time between changes? Mahalo.
sfjen is offline   Reply With Quote
Old 06-19-2011, 01:06 AM   #4 (permalink)
so what oil would u recommend i use 20w-60 or the extra thick stuff?
Old 06-19-2011, 04:20 PM   #5 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
you will kill your oil pump with that thick of oil
dem2757 is offline   Reply With Quote
Old 06-19-2011, 04:22 PM   #6 (permalink)
dem2757's Avatar
the car was meant to use 5w-30 colder weather or 10w-30 in warm weather. This is basically the thickness of oil the pump can handle, and the tolerances can handle. too thick and you are not gonna get enough oil to certain parts, same thing if its too thin.
Old 06-20-2011, 01:28 AM   #7 (permalink)
Well using one grade higher on your hot side is an old trick to help slow down leaks and oil consumption. And on that note 20w-60 is way too thick. I think 10w30 is recommended OEM but I feel that 10w-40 runs a little better on my car and helps protect alittle better in hot ass Texas.
Old 06-20-2011, 07:34 AM   #8 (permalink)
dem2757's Avatar
10w 40 would be fine as long as thecar uses it only in the hotter weather. nothing higher though please for the sake of his engine!!!! haha
Old 06-21-2011, 07:11 AM   #9 (permalink)
ok what about 20w-50?
Old 06-21-2011, 02:39 PM   #10 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Way too thick. You're looking at diesel weights with the 50 and 60w oils. I recommend 10w40 max during summer running if you live somewhere hot. I run 5w30 in winter and 10w30 in summer where I am and I'll still sometimes catch the idiot light for the oil.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 06-22-2011, 02:22 AM   #11 (permalink)
View Lee250's Photo Gallery
I've been using delo 15-40 diesel oil for years. Slows the oil leaks and never had any negative side effects.
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 06-22-2011, 10:41 AM   #12 (permalink)
View JOET/CAMRY's Photo Gallery
I have a 1989 Camry with 272,000 miles on it and I use 20w-50 in it year round with no problems at all. The cars rear main seal has been leaking for at least 2 years now and I have been using the thicker weight oil to slow the leak down. Really dont feel like pulling the transmission to replace the seal. It works for me. Yah that 20w-60 oil might be a little too thick.
JOET/CAMRY is offline   Reply With Quote
