Overdrive light not coming on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2011, 02:08 AM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 Overdrive light not coming on
99% of the time my overdrive off light doesn't work but every once in a great while it will come on first thing in the morning but after I turn it on and off a couple times that's it for a couple months. The overdrive works fine and it's not the bulb or contacts. Anybody else have this problem?
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 06-19-2011, 04:19 PM   #2 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
you dont want the light to be on when the od switch is pressed in. only when it is in the off position do you want the light one
if it comes on when the car is started you have a short in your solenoid/speed sensor circuits or the sensors, or your CPU is going bad
dem2757 is offline   Reply With Quote
Old 06-20-2011, 07:46 AM   #3 (permalink)
View Kingdom934's Photo Gallery
Overdrive light when on = overdrive is turned off. The car won't get into overdrive gear (4th gear). Recommend to have the light off (overdrive enabled) to enable 4th gear. Useful for highway cruise speeds. Only time you want to turn off overdrive is if you want to use engine braking or climbing a steep hill when the transmission keeps hunting for gears (somewhat more common with the gutless 2SE)
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
