Problem after Tail Light Sensor Bypass 1991 Camry Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2011, 01:28 AM   #1 (permalink)
View ssla's Photo Gallery
2nd Generation Problem after Tail Light Sensor Bypass 1991 Camry Wagon
Hi everyone!
My tail lights went out and after checking the bulbs and fuse by the driver side door I found a fix online that had me find the Light Failure Sensor in the trunk and bypass it by clipping off the wires and connecting them to each other.
The problem is, after doing this the brake lights are now always on when I have my lights turned on and the tail lights still don't work.
The other strange thing is that when I don't have the lights on, pressing the brake pedal now causes all the lights in the rear that work to turn on (the ones on the sides, and the license plate light)
I connected the green and red wire to the green and white wire, and then the light green wire to the other green wire. I taped off the two yellow wires and left the ground as is and also tried connecting it to the body.
My headlights, turn signals, reverse, and the side lights in the rear all work.
Any help would be greatly appreciated!
ssla is offline   Reply With Quote
Old 06-27-2011, 01:04 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
Doesn't sound like you bypased it, looks like you just wired the brake circuit into your parking light circuit for the rear lights. I suggest you put everything back and find the real problem, like a short, bad bulb, blown fuse, or bad sensor box. I think someone posted about how to fix the box awhile back search for it.
Old 09-05-2011, 12:52 AM   #3 (permalink)
View ChevyToughRebel's Photo Gallery
I had this happen on my car, and another car. It was indeed the light failure sensor box. The fix was re-soldering some of the circuitry that had broke loose from the circuit board. As long as its not burnt up too bad.
ChevyToughRebel is offline   Reply With Quote
Old 09-05-2011, 06:26 AM   #4 (permalink)
mcx
View mcx's Photo Gallery
where is the light failure sensor box on a 91 sedan?? thx,mike
mcx is offline   Reply With Quote
Old 09-05-2011, 07:37 AM   #5 (permalink)
mcx
nevermind...i found this thread.
1989 Camry Tail Light Yellow Box Sensor Inside Trunk
Old 09-05-2011, 11:07 AM   #6 (permalink)
Yep, there's some good info in there. I see that some of the guys say to jumper and install a fuse between wires. If you have the ability, I would recommend re-soldering the loose joints if that is the issue with yours. Im not the only one thats had that same problem, super easy and free fix if you have the tools. Good luck
~ Shane
