Throttle Cable and Shifting
Can a bad or not adjusted correctly throttle cable cause automatic transmission shifting issues? such as, shifting into first gear too soon and with a jerk.
I've noticed that if I play around with the throttle cable it will affect the accelerator pedal resistance and also when the transmission shifts into first gear. I'm not talking about adjusting the cable nuts that hold it to the bracket at the throttle body, just moving and pulling the cable around.
I did notice that the rubber sleeve surrounding the cable has broken off from the end that is located behind the neutral safety switch, so I can expose quite a bit of cable by pulling up on the sleeve.
Perhaps I should order a new one and replace it? Anyone have experience in doing this, the manual says to just pull the old one out and put the new one in and make sure you push it in far enough.....sounds too simple.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
