Transmission Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2011, 08:03 PM   #1 (permalink)
View sleep_deprived129's Photo Gallery
Transmission Help
I have an '88 Camry with a manual transmission. I am thinking of replacing the oil in the transmission with some synthetic to possibly help with less than great third and reverse gear perfoamances. What kind of fluid does it take? I have a repair manual and it has a couple different types listed, ATF Dexron II and 75W-90/80W-90. I would bet the gear oil is correct and the other is incorrect but I wanted to be sure. Thanks for any help.
sleep_deprived129 is offline   Reply With Quote
Old 06-29-2011, 10:55 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
3S-FE equipped car takes Dexron-III or equivalent, 2VZ-FE takes 75W-90 gear oil.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 06-30-2011, 10:58 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Factory fluid on the 3s-fe 5-speed is Dexron ATF (originally II, now III). Many people have had good luck swapping over to a standard gear lube despite that fact.
I would suggest one quart GM Syncromesh with the rest a standard gear oil (GL4 rated or a GL5 rated oil that is also rated safe for 'yellow metals').
You shouldn't need to go to a synthetic oil to reduce syncro problems, in fact, you want to avoid synthetic oils as it will make it harder for the syncros to work.
-Charlie
