You know you probably could have swapped the complete 3s-fe intake manifold, right? That would have solved the throttle body/tps issues.
As for the injectors - yes, change them to the 3s-fe ones. Since you are using the 3s-fe ECU, you should use the injectors matched for it.
The motor may never run 100% right since you it has a different displacement and cams... but it should be generally ok.
-Charlie
