Dash indicators “Charge --Brakes—Lights” remaining on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2011, 06:20 PM   #1 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Unhappy Dash indicators “Charge --Brakes—Lights” remaining on.
The car had been sitting for three days, I started it up & drove it ~ 200 ft, hit a couple of rough spots on a gravel road, they lit up like a slot machine... and stay lit " whished I was"
I un-hooked the “B”-wire from the alternator and measured 14.9 VDC at 2,000 rpm.
The alternator appears to be charging strong, is this an indication it’s about to fail or is there something /somewhere I should be checking?
The battery is sitting at 12.7 VDC
Hate like hell to get stuck somewhere
Sturdavj is offline   Reply With Quote
Old 07-14-2011, 11:52 AM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Those lights mean that the regulator thinks that something is wrong.
How is the voltage at the battery when the motor is running at ~2k rpm (with all the wires hooked up)?
Reseat the alternator plug too.
Conceivably the the small fusible link (hidden in the harness, I think...) could be busted. Check for 12+V at the small white wire at the alternator to check that fusible link.
In fact, all the wires at that connect to the alternator (3 small on the plug, 1 big on the stud/nut) should be at 12+V when the car is running...
-Charlie
Old 07-14-2011, 03:39 PM   #3 (permalink)
What is the best way to test for VDC at the alt plug ? (3-wire)
Can it be probed from the backside while still conected?
Old 07-15-2011, 10:53 AM   #4 (permalink)
white90dx's Avatar
It is probably a sealed connector. You would have to use a sharp probe through the wire insulation, I think.
-Charlie
Old 07-15-2011, 11:11 AM   #5 (permalink)
There is 12VDC on the male side (wire) of the plug, 0 VDC on the female side (Alt socket) . It appears that I am not getting any output now.. from the “B” no change with the RPM
I pulled the Alt, I plan to have it bench tested this afternoon, The brushes have about ˝” remaining and the commentator looks good, I am thinking it might be the Reg.
I have located a salvaged one for $30.00 w/core EX
I am thinking I'll go this way after bench test
Old 07-15-2011, 09:45 PM   #6 (permalink)
Replaced defective alternator with one from salvage yard, lights are now out
Old 07-17-2011, 01:09 AM   #7 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $654020
View 84Cressida's Photo Gallery
Almost always when all the lights on the dash are on, it's the alternator. That's an easy way to figure it out on older Toyotas.
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is offline   Reply With Quote
Old 07-18-2011, 08:52 AM   #8 (permalink)
What threw me was when I first tested w/multi-meter the alternator was producing ~ 14 VDC.
I had done an AT R&R earlier and thought I might have loose Elec. connections. After TS the wiring I came back to the Alt & sure enough I had a hard fail at the Alt. Bench tested it and no VDC output. R&R w/salvaged unit, everything is fine
Thanks for your input J
