Turbo or N/A? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2011, 05:44 AM   #1 (permalink)
TWO-VEE-ZED
TWO-VEE-ZED's Avatar
View TWO-VEE-ZED's Photo Gallery
Australia Turbo or N/A?
The 2VZFE in my 91 Camry has seen better days even though it still pulls like a train.My question is,should I rebuild it with a turbo or leave it in naturally aspirated form?
TWO-VEE-ZED is offline   Reply With Quote
Old 07-14-2011, 12:07 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
We can't answer that question for you...
What do you want to do with the car? What is your budget? What are your power goals? What experience do you have building N/A or turbo cars?
Answer those questions either here or for yourself to get you going on the right path. Keep in mind that either path is not heavily traveled...
Another option is go go with a modern Camry motor (1mz, 3mz, 1/2/3GR, etc.) - any of those would be an interesting swap and get you 200+hp...
-Charlie
Old 07-14-2011, 12:15 PM   #3 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
how many miles or kilos you got on it? if over 200000 miles id say leave it.
i love the 2vz fe but youd have to change out a lot of parts to run like 10 psi of boost.
edit: if you have the auto tranny youd need to swap for a manual the internals would be blown out by increased torque and power.
dem2757 is offline   Reply With Quote
The Following User Says Thank You to dem2757 For This Useful Post:
TWO-VEE-ZED (07-14-2011)
Old 07-14-2011, 01:29 PM   #4 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
why would you spend that kind of money and time rebuilding a 91 camry with turbo? i don't see how it would be worth it, given that it is a camry and how old it is.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 07-14-2011, 02:21 PM   #5 (permalink)
TWO-VEE-ZED
Why?...Why do people take oddball cars and modify them?
Old 07-14-2011, 02:25 PM   #6 (permalink)
TWO-VEE-ZED
It has 240,000 kms on it and an auto tranny.I don`t want to be fitting 1MZs or anything like that.My point is:Is the 2VZFE robust enough to either receive boost or be modified in N/A form?
Old 07-14-2011, 03:08 PM   #7 (permalink)
dem2757's Avatar
you can get custom parts for it, there is not a big support for the 2nd gen aftermarket performance though.
build a y pipe under the engine though, that helps a lot with the hp and flow of the engine. the ugly crossover robs it of power and heats up the rear bank too much.
IF YOU TURBO IT::::::
you need to get new pistons and a new crank. re-bore your block or get a new block and heads from a lower mileage engine. the internals of the 2vz ARE strong enough to handle boost IF the crank and pistons dont have age. if you boosted it without modifying the internals youd probably throw a bearing. probably gonna need to clean your injectors or get better flow ones.
Modifying the N/A engine would be cheaper and easier
Turboing would be $$$$$$$$$
Old 07-14-2011, 11:50 PM   #8 (permalink)
TWO-VEE-ZED
Thanks again mate.The N/A route sounds like the most practical.I suppose the y pipe would lend itself to the easiest turbo installation ever but the internal work on top sounds elaborate...I`m crazy,but not foolish I suppose the exhaust,cams and some head cleaning up should provide me with sufficient power huh?.
Old 07-14-2011, 11:57 PM   #9 (permalink)
dem2757's Avatar
very much so. just build the custom y pipe to get the better exhaust flow and then clean up your top end for best results. add a cold air intake and relocate your battery to get the better air flow.
Old 07-15-2011, 11:23 AM   #10 (permalink)
white90dx's Avatar
Really though, what are your goals? What is sufficient power? Answer those questions honestly first, and then you can more easily figure out a plan of action.
If you want 20 more horsepower - keep it N/A. If you want 100 more horsepower... well, forced induction is much more cost effective (actually, a motor swap would be better at that point...).
-Charlie
Old 07-15-2011, 01:16 PM   #11 (permalink)
if he wants 100 more HP, he's going to need a driveline replacement, suspension replacement, frame stiffening, better/wider tires, fuel system upgrade, etc. etc. etc.
Old 07-15-2011, 02:00 PM   #12 (permalink)
dem2757's Avatar
exactly. just add 30-40 with some tune ups and youll have a decently quick car. the 2nd gen isnt a heavy sedan so pulling 180-190 would be fun, especially with a 5 speed.
Old 07-15-2011, 06:58 PM   #13 (permalink)
TWO-VEE-ZED
-Charlie
Ok,here`s the low down.The vehicle which I happen to possess here in Australia wasn`t manufactured in high numbers,at least not with all the extras and "imported from Japan" V6.Now,as far as I know,this version (with V6) never had a manual as an option,thus leaving me with a dilemma of sourcing a manual gearbox.Then,there`s the rest of the driveline to consider as well such as diff,driveshafts etc,and then you have compliance.I`m not sure how the laws work where you are but here in Oz,you can`t just fit a turbo to a non turbo manufactured car and go un-noticed,especially by the cops or road traffic authority who may pull you over.Hardly worth the hassle for 70 odd kilowatts,doncha think?I may as well stick with the N/A and auto trans,which I`m sure with a cooler and shift kit would be happy with even up to 50 extra N/A kilowatts.I`m sure this is achievable without a turbo.You see,this car was purchased recently as a project in mind.Budget for the car is $5000 AUD,with much of the work,including body performed by myself.In fact,the only outside work may well be the suspension,in as far as labour goes,that is,and labour,as yuo well know,eats up a big portion of one`s budget.I`ve done it to other cars in the past with mods of varying degrees,then sell them as I get bored.It`s not gonna be a show stopper or a quarter mile tearer,just a comfortable cruiser with some added grunt to add to it`s looks.The suspension will be lowered after I repair a bit of rust and a couple of dents.It will be out of the ordinary,yes,but then again,I`ve been known to always seem to modify the cars that others won`t
Edit:The budget is obviously revised without a turbo in mind.Another 3 grand or so would have been added for forced induction.You see,I`m the type that would purchase a turbo,or a wastegate,or a cold air induction and throttle body set-up on Ebay or the wreckers,or add a piggy back chip to the ECU rather than a Wolf 3d or,tell my friend at the exhaust shop that I want the least expensive yet most effective set-up for either turbo or N/A,or purchase and fit/have fitted the least expensive yet most effective suspension set-up,or straighten and paint my own car.It may be inexpensive,but cheap it ain`t.Everything I`ve done and in most cases,had done to it was done properly.
Old 07-15-2011, 07:21 PM   #14 (permalink)
TWO-VEE-ZED
Unfortunately mine is mate.With the whole caboodle(Electric windows,power this and that and blah blah),it weighs in at around 1300 kgs-fairly heavy,even for a V6 of only 2.5 litres.Then again,in the Toyotas they have here,the Japs are famous for saddling heavy bodies to otherwise decent,but in this case not quite right for the job engines.Another example is my ex`s Soarer which I personally purchased whilst in Japan in `99.It has a N/A 2JZ-A beaut and powerful engine,even without a turbo,yet when fitted to a car that weighs almost two tons,it lacks a bit in the take off department,as does my Camry.With another 40-50 kilowatts and more torque,it should hopefully overcome that
Last edited by TWO-VEE-ZED; 07-15-2011 at 07:48 PM. Reason: Made a mistake in wordin
Old 07-16-2011, 01:56 PM   #15 (permalink)
white90dx's Avatar
My suggestion:
Manual swap (yes, it can and has been done in Aus/OZ, search "JetSpeedCamry" here) and headers/full exhaust. That will get you the speed you want (it will probably be 30-40% more power at the wheels) and you won't have any problems with engineering/safety inspections.
Too bad though, because for your budget you could have close to 300hp from a 3s-gte... (but down there would require upgraded brakes, and the inspections, etc.) It is all illegal up here, but it isn't too hard to stay 'under the radar' about it.
-Charlie
