Originally Posted by white90dx
The overflow bottle shouldn't be full (when cold) - the cold fill line is just above the lower 'bulge' in the tank. If you have it filled to this level when cold and it overflows, you have a problem.
Replace your radiator cap to start with...
-Charlie
I topped off the overflow, after I flushed & changed the coolant , my friend told me to top it off in case the block didn't have enough coolant .. I think It may be overfilled, but I am going to replace the cap just to be safe , the rubber seals looked a little cracked.
