Originally Posted by mlkovacs
Hi, I am shopping for an egr valve for my 86 camry le with a 2SE motor. I found one on ebay but its from an 83 to 85 camry le. The valve looks identical with only one vacuum lead on top and one vacuum lead on the bottom that goes to the egr vacuum modulator. Thanks.
I would think if it is from the same motor (2SE motor) than it should be identical. The 1st generation Camry was from the years 1983 - 1986. You could look up on an auto parts website like auto zone or advanced auto and see if the part numbers match for the years 83 - 86.
Could You not just clean off the carbon buildup on the egr valve you have now. I cleaned the one on my 1989 Camry 4 cyl. and made sure it opened and closed propery and it has been working fine.
This was around 5 years ago.
