delay for wipers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2011, 05:48 PM   #1 (permalink)
View Lee250's Photo Gallery
delay for wipers
Is there any aftermarket wiper delay set ups that would work on an 86?
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 08-09-2011, 09:11 PM   #2 (permalink)
View dlgg7's Photo Gallery
Have you checked at JC Whitney? I know I've installed several on vehicles over the years that where aftermarket I bought at one of the local auto parts stores like Autozone. I've used ones that came w/control that clamps to the left turn signal handle, and one that had a knob that could be mounted on the dash somewhere.
dlgg7 is offline   Reply With Quote
Old 08-09-2011, 09:23 PM   #3 (permalink)
Yep, I just did a search on ebay and found 2 under universal wiper delay, and at JC Whitney 2 also! Good luck!
Old 08-10-2011, 06:17 AM   #4 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
On gen2 Camrys, many of us found that if you replace the standard wiper stalk with one from the LE model with variable intermittent wipers, it worked.
gen1 Camry is probably set up the same way. If you see a gen1 LE in the salvage yard, you may want to buy the wiper stalk and try it.
on eBay they are called combination switch. You see them for later model Camrys, but haven't seen one for a gen1.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 08-15-2011, 08:01 AM   #5 (permalink)
mcx
View mcx's Photo Gallery
WOW Good tip!!...is it difficult to swap over on the gen2?? I hate the wiper speeds on my 91 DX
mcx is offline   Reply With Quote
Old 08-17-2011, 11:09 AM   #6 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Pull the plastic covering (three? screws) and the steering wheel (one 8mm bolt to remove horn button, 19mm nut to release wheel. Leave nut on a couple turns and rock wheel forward and backward at the top and bottom to remove from splined shaft) and then when you've got the wheel and the plastic covering removed, it's I want to say three screws to release the combo switch and then unplugging it.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
