Clearly it's too much to ask for me catch a fucking break. Everything I do has to be the hardest most complicated thing every created by Toyota. So I'm having issues lately with starting. I did have a real problem with my battery it was leaking and was going bad so I replaced it and all was new. Then for some reason I can't start the car sometimes. I cleaned out the Neutral Safety switch and it seemed to fix it. Then the other day it started up again. I figured ok it's the lock cylinder since I can actually take my key out while the car is running and nothing happens and proceed to take apart my steering wheel assembly.
I take off the covers off and see that I need to remove the wheel to push a pin into the access hole while having the key in acc mode like the book and alldata says but for some reason it's not coming out. So I remove the screw holding the ignition switch from the back off the lock cylinder and I see what the problem is. First of all, the lock cylinder that I bought from autozone has the wrong size arm on the end that goes into the ignition switch. I look at rock auto and they all have the same piece of shit JUMBO size lock cylinder arm(mine is obviously less than half of the size that I bought and that rock auto shows) so clearly I am going to have to pay an arm and a leg at the dealer to buy one for my car since my car just happens to have a tiny itty bitty lock cylinder arm. Furthermore, it's obvious I'm going to have to buy a key unless my original manages to work unlike at autozone which comes with keys.
Now I see another problem. There is some kind of piece at the back end of the lock cylinder arm that is not going to allow it to be pulled out even when I do press the pin in. No matter how far I turn the key to "on" the piece is about an 1/8th of a turn short of being lined up with a cut out that will allow the lock cylinder to be pulled out from the front. That piece is attached to the lock cylinder head and I figure I'm going to have to break that piece off to get the assembly out however looking at the toyotapartszone website it's clear that I have to buy the whole assembly which obvious nothing I currently have tells me how exactly to install the assembly properly so I'm going to have to wing it.
http://www.toyotapartszone.com/Page_...reName=MEL160A
http://www.utoyot8.com/FullImage.asp...288807-++++%29
Here's something else, I am not 100 percent certain that it's the lock cylinder that is the problem. What I've been doing the last day or so is wiggling the black piece/assembly that you need to push in to get the key out(it has a couple springs on it and sits at the top of the lock cylinder) and that appears to make it want to start so I clearly need to buy that assembly as well. However, I'm not sure which part it is. I'm hoping it's the 84532 solenoid assembly that is showed.
Anyone have any ideas on this.
