1990 Camry Manual Transmission Fluid Question
Hi All!
I've got a 1990 Camry 5-speed manual. The transmission grinds when shifting from 1st to 2nd, or downshifting from 3rd to 2nd. I can always get it in gear, but not without a horrific noise.
The grinding only occurs when it's hot outside, or after the engine has been running for awhile. To avoid grinding during these situations, I can clutch MUCH longer, and let the RPM's drop to basically idle before shifting; Or I can double-clutch.
Since the grinding was related directly to temperature, I thought that maybe the fluid was old and the viscosity had broken down and had become very thin, especially when it's hot. So, about 1 month ago I tried replacing the transmission fluid with 1/2 Dex/MERC ATF and 1/2 Lucas Transmission Fix. I've had no noticeable improvement.
I'm wondering if putting something higher viscosity, like 90w gear oil, into the transmission would be another solution. Or, if that's a bad idea because the 1990 Camry can only run ATF. Is there a possibility of damaging the transmission by trying this?
Thoughts?
Thanks!
