1991 Camry All-Trac Transmission Engagement Issues
Hey Guys,
I currently have a 1991 Camry All-Trac Automatic (117k on driveline and chassis) with some transmission engagement issues. The problem is as follows:
Initially, when shifting into reverse the car would make a light grinding noise and would hesitate to go backwards when giving it gas (i.e. it would free rev a bit before engaging and sometimes it would not engage). Sometimes reverse would work perfectly fine without any noises. No other gears would make any noises. All other gears worked fine, shifting was very smooth (i.e. no lurching, starting from a stop was smooth). Fluid levels and color are good.
Recently the car stopped making the strange reverse noises, but there is no longer reverse gear 90% of the time (i.e. the car will just free rev in reverse without going anywhere). When shifting into drive or any other gear, the car will occasionally engage and run very smoothly, but sometimes it will not engage at all and free-rev like reverse (~25% of the time). Sometimes when driving in stop-and-go traffic the car will disengage from the transmission and free-rev. At highway/freeway speeds, the car will never randomly disengage. Again, there are no noises to speak of and the car runs incredibly smooth when the transmission actually engages.
The problem has gotten progressively worse to the point where I’ve parked the car. I’m planning to go to the local junkyard this weekend and pull a torque converter to change out with mine to see if it makes a difference.
Does anyone have any insight into this problem? It seems like a torque converter issue to me as the car runs and drives very smooth when the engine can actually deliver power to the transmission. However, as I’m going to be pulling parts off of a car, any insight into any additional parts I should replace while I’m in there would be very helpful.
Also, does anyone have links to transmission removal or servicing for this vehicle? Are the torque converters/transmission components interchangeable between the FWD camry’s and the all-trac’s?
Thanks!
