Specifics - Rear Disc Brake Conversion 2nd Gen Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2011, 07:02 PM   #1 (permalink)
View 89Camry89's Photo Gallery
2nd Generation Specifics - Rear Disc Brake Conversion 2nd Gen Camry
I have been through the archives on this and attempted to find the answers out on the web. The old URLs are now dead. The general advice was ok, but these cars are getting old enough that I can't just go find one in a nearby junkyard.
I am trying to compile a list of cars that can be donors for the parts I need to do a rear disc brake conversion on a 1989 Camry LE as well as the specific names of the parts I want to find.
I presume I need the rear knuckle, caliper, and wheel hub. But is that all? (Plus parking brake hardware.)
If I am going to call distant salvage yards, search on ebay, or search online, I want to be sure I am using the most accurate terminology. When I query on second hand sites like car-part.com I often don't see categories for rear knuckle, for example. The local parts shops tell me that the aftermarket industry doesn't manufacture replacement knuckles.
If I follow along correctly, all 2nd Gen Camry V6 models were rear disc and would work as donors for me.
How about the first generation 1989-1991 Lexus ES 250 as a donor?
The calipers on the 3rd Gen Camry's appear to be the same in pictures and in one section I found a matching part number when I cross-referenced. Are the 3rd Gen rear knuckles different than the 2nd Gen?
Your knowledge is appreciated.
89Camry89 is offline   Reply With Quote
Old 08-25-2011, 07:09 PM   #2 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Just find a camry in the yard with rear discs- you need the complete knuckle, the section of brake house that bolts to the calipers, and the paling brake lines. The knuckle will bolt to your rear control arms and struts.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 08-26-2011, 10:51 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
ES250 rear brakes are compatible. 3rd gen Camry rear disks (also V6 only) are not compatible - the caliper may be the same, but many other parts are different.
-Charlie
Old 08-27-2011, 02:14 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Originally Posted by '88 All-Trac View Post
you need the complete knuckle...
Are you sure? I did a rear disc conversion many years ago, and I remember just swapping the back plate.
-Charlie
Are the ES rear brakes different than the V6 Camry?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 08-27-2011, 02:26 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
nope the ES is basicly the v6 camry with leather seats and minor body changes
Old 08-27-2011, 02:29 PM   #6 (permalink)
71Corolla's Avatar
True, the ES250 was as close to a Camry as the ES ever got. But the ES300 had bigger discs in the back vs. the Camry so I was wondering if that was also the case for the ES250.
Old 08-27-2011, 07:19 PM   #7 (permalink)
Not entirely sure, I just grabbed the entire knuckle for the ease of the swap.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 08-29-2011, 11:11 AM   #8 (permalink)
white90dx's Avatar
ES250 rears are the same as gen2 V6 Camry - the fronts may or may not be different, depending on year and options (mainly ABS).
-Charlie
Old 09-07-2011, 12:50 PM   #9 (permalink)
View modMonkey's Photo Gallery
Is there anything special that is needed to convert the drum e-brake to the disk e-brake?
1991 Camry Station Wagon - 270K and counting
modMonkey is offline   Reply With Quote
Old 09-07-2011, 02:00 PM   #10 (permalink)
Just the cables that go from the handle to the brakes. Nothing else is needed.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
The Following User Says Thank You to '88 All-Trac For This Useful Post:
modMonkey (09-07-2011)
Old 09-07-2011, 02:47 PM   #11 (permalink)
Ah, for some reason I thought the ones from drums could be reused. Is it difficult to disconnect the one from the e-brake? I'm always weary of being under junkyard cars for long periods of time, especially since they are usually held up by objects of questionable integrity.
Old 09-07-2011, 03:46 PM   #12 (permalink)
It is actually quite easy, especially if the cables are removed from their mounts between the discs and the handle- they function the same way as the throttle cable. Get some slack in the line, rotate them on their peg, and they slide right out. You can reuse everything else for the parking brake, you just need the cable... Handle-side stuff is all the same.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 09-07-2011, 03:48 PM   #13 (permalink)
sweet! thanks!
Old 09-07-2011, 10:00 PM   #14 (permalink)
Any time! Really, anything I can do to help prolong the interest in the Gen 2. I love these things!
If you get any more questions, just ask... I'll do my best and if I can't answer, Charlie (white90dx) sure as hell can.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 09-07-2011, 10:24 PM   #15 (permalink)
Will do! My car holds huge sentimental value for me, going to keep her running forever if i can
