'90 Camry throttlebody issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2011, 07:46 PM   #1 (permalink)
Highmile Camryguy
View screenflot's Photo Gallery
2nd Generation '90 Camry throttlebody issues
OK folks, here's my dilema. '90 camry 3sfe auto, 250k miles. The car was running perfectly before I decided to clean the pcv pipe. The opening at the thottle body was completely clogged with crud so I scraped what I could out with a screwdriver. When I started it, I'm sure a bunch of the crud was sucked into the engine. It ran rough for a few minutes and then wouldn't start. I removed and cleaned the throttle body with t-body cleaner and blew out all the ports with compressed air. Nothing is clogged. Then removed and cleaned the EGR valve. No leaks, not clogged or stuck open. Compression is 150 in three cylinders and 140 in one. Have spark and fuel. After sitting for a few days, it might start with difficulty and idle ok but stumbles upon any acceleration. Holding the throttle open it sounds like it has a miss. The plugs are sooty black (not oily) indicating a very rich mixture that I can also smell. Maybe I have damaged the IAC valve or TPS with the t-body cleaner? Can I test these? any help will be greatly appreciated! Thanx! Rodger
screenflot is offline   Reply With Quote
Old 08-29-2011, 08:02 PM   #2 (permalink)
Highmile Camryguy
I forgot to add that there are no codes.
Old 08-30-2011, 10:56 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Change out those spark plugs - NGK or Denso standard coppers, please. It should be a cheap thing to try.
Any chance you have a broken intake pipe (between the airbox and throttle body)?
The cleaner is unlikely to have caused problems with the TPS or IAC...
-Charlie
Old 08-30-2011, 02:06 PM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Make sure you have not pulled out any wires leading to the sensors nearby
Doctor J is offline   Reply With Quote
Old 08-30-2011, 09:25 PM   #5 (permalink)
Highmile Camryguy
2nd Generation
Plugs are good, no holes in airbox tube, and all connectors are tight. I would think I would get a code if one of the sensors were bad or unhooked. When I can get it started, which is rare, you can smell the rich condition really bad. This leads me to think maybe the throttle position sensor is sending an open throttle signal even when it's closed. Don't quite know how to test it. Hayne's manual has some tests but none seem conclusive. Maybe start swapping out sensors from a junkyard? Need to get this car going. Shootin' for 300k miles!
Old 08-31-2011, 02:53 AM   #6 (permalink)
View holmesnmanny's Photo Gallery
go to alldatadiy.com to purchase a subscription but first do a search for an online discount code. You're going to have to adjust the tps when you put the new one on, but ya that's what I would do, assuming you're certain that you didn't yank any wires out of any electrical connectors.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 08-31-2011, 08:29 AM   #7 (permalink)
Doctor J's Avatar
Do you have a good spark every time you cranking an engine?
if you have teradrop 4 connections TP sensor the car may run with unplugged one (my 87 does) the box type sensor will set the code 51
Also peform the idle speed control valve check as I described in one of my threads
Idle speed control valve ispection/service
