Hey guys,
The vehicle in question is a 91 camry all-trac automatic
So I currently have the engine supported by the pass-side mount and I'm attempting to pull the transmission + transfer case out as a single unit.
I have everything unhooked from the tranny + transfer case including the prop shaft and I've separated the transmission from the engine ~ 4 inches (far enough to where the torque converter fluid is leaking out from the bottom.
However, the transfer case is getting caught up against the engine block. Is there any way to take the transfer case + transmission out as a single unit? Would separating the transfer case from the transmission allow for removal of the transmission?
I didn't want to drop the entire engine + trans as a single unit, but it seems like it may be easier to go this route. Currently I have the engine supported with a floor jack, and the transmission with a chain + engine hoist.
Thanks guys
