Hi!
The brake system light (same as hand brake light, see picture in bottom of post) on the dashboard of my '91 Camry GLI 2.0 (manual gear) stays lit all the time while driving.
When I start the car the light is off, but as soon as I press the brake pedal once the light illuminates. The brake fluid level is ok and the brake pedal feels normal. The light is on despite the parking brake is not activated.
This problem emerged after I left it for a repair concering an other issue and had my registration plate lights changed at the same time. Ever since it's been the same, once I brake the light stays lit.
I've tried to mess around (and clean) with the contact to the rear brake lights without any results.
Any ideas on why the light stays on? What can I do to fix it?
Thank you.
