intermitant starting problems; is it the starter or something else??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2011, 08:46 AM   #1 (permalink)
View jaansu's Photo Gallery
In my 90 Camry, I had the starter replaced last year after a series of starting problems. Occasionally, turning the key only produced a single click. Either retrying, shifting up and down, trying it in neutral or hammering on the starter, eventually started the car. Not clear if any of these actions were really effective since sometimes it started if you tried it enough times.
The problem has returned and recently the percent of failures to start the first time has increased. Again, just a click and at no time have I been stranded - eventually it starts. My only observation is that it seems to make a difference sometimes if I put a little more torque on the key. Can the problem be in the key contacts?
Since the problem never seems to occur when it is in the shop, they can't easily help me. Does it sound likely I got a poor starter, I assume it was rebuilt, or could it be another problem? I drive 50 miles to work each day and would hate to be stuck that far from my indie shop.
jaansu is offline   Reply With Quote
Old 09-13-2011, 12:32 PM   #2 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
You may need to do the starter relay mod... But I haven't encountered that particular problem yet so I can't give you much help.
Try doing a quickie search for starter relay here on the Gen 1/2 forums.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 09-13-2011, 12:56 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The link to the starter relay thread is in one of the stickies at the top of this section. It should solve your problems.
Until you get to that point, try starting the car with all accessories off (radio, fans, brake lights, head lights, etc.) and see if that improves things until you can really fix it.
-Charlie
Old 09-13-2011, 02:50 PM   #4 (permalink)
sticky
I did read the sticky but I wonder if it applies to my problem. The sticky indicates 'no start, no click.' I get a loud click each time I turn the key.
Old 09-13-2011, 06:13 PM   #5 (permalink)
Gameroom cash: $303055
Do a search on this forum for "starter contacts" and read up on that problem and it's cure. It's been covered numerous times. That sounds more like your problem to me.
Mike
