Not that difficult. You'll need to remove:
- Left side kick panel
- Front and back rocker scuff plates (bottom of door sill)
- B pillar cover(behind seat belt), no clips just lift up and pry carefully out, or leave in place elevated
- Back seat bottom (two clips, pull forward)
- Back seat left side bolster (12mm bolt at bottom, covered by a piece of carpet
- Left side vertical trunk liner (3 x-mas tree clips)
That's about it, you can then pull the green plastic anchor clips off the rocker panels, and stuff your wires into the existing loom shield/cover. I would wrap your wires with electrical tape to prevent possible wire chafing.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
