When the cat warrants being rodded out, it is increasing emissions if anything; the ridiculous fuel usage at high speeds is a real drag.
It will no longer burn CO into CO2 but your mileage has the potential to increase drastically. Remember, though, that the car will be somewhat louder unless it i a Cal-spec emissions vehicle, which will have a second one mounted under the engine. If you would like to retain a catalytic converter, you can have a 2" - 2 1/4" unit welded in at most exhaust shops for a reasonable price, but a replacement stock unit can run several hundred dollars... Which is why I rodded mine out and then because the car doesn't need to be smogged I straight-piped it and slapped on a glasspack. I went from pulling 27mpg highway on a good day to 38mpg if I'm trying- 30-35 with regular cruising.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
