Heater and washer nozzles? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2011, 05:09 AM   #1 (permalink)
WhippinCamry's Avatar
View WhippinCamry's Photo Gallery
USA Heater and washer nozzles?
Havent posted in a while. hopefully everyones doing good.its getting cold up here in michigan and for some reason my heater does not turn on at all now. worked great last winter. ac doesnt work.
and also my spray nozzles for my windshield are not working.
i visualy checked all fuses and none looked bad. test with a fuse tester?
i also heard about soldering a connection in the heater panel.
i just need to get this worked out soon or i might freeze here soon.
thanks again toyota nation!
WhippinCamry is offline   Reply With Quote
Old 10-01-2011, 07:17 PM   #2 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
When you say the heater isn't working do you mean the blower or there's just no heat? If the blower isn't running try it in high. Let us know. As for the sprayer nozzles I would check the fluid level first. With the hood up you may want to pull a hose off a nozzle and put it in a jar or something and then try them. If fluid comes out the nozzles are probably clogged. If not the pump may be bad or there's an electrical issue keeping it from running.
Dave's is offline   Reply With Quote
Old 10-03-2011, 11:09 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Do you have a base/DX model or an LE model?
-Charlie
