Alternator charging question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2011, 11:38 AM   #1 (permalink)
88 All-Trac
empersons's Avatar
View empersons's Photo Gallery
2nd Generation Alternator charging question
I am trying to figure out the charging system on my Camry. Does anyone know what the voltage should be coming out of the alternator where the 3 prong plugs into the side?
maybe someone can school me on how an alternator works, what the power wire going to and from do, etc?
Thanks all
Eric
PS - if anyone cares, I have successfully changed the clutch on this, changed cranks and cam seals, and reinstalled the engine. All with the help of my good friend Luke and from Charlie (white90dx) from the forums and messages. Thank You
Oh yeah, and it started right up
Eric
1988 Camry All-Trac
Pictures
empersons is offline   Reply With Quote
Old 10-04-2011, 02:09 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The voltage you should really be worried about is on the big bolt-on connection, not the 3-pronged plug.
With the engine running, you should be getting >13V there. At higher than idle, it should be around 14V.
Why are you suspecting a problem?
-Charlie
Old 10-04-2011, 02:14 PM   #3 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
technically, the nominal voltage of a car battery is 12.6 volts (2.1 volts per cell X 6 cells). this is approximately what you should get with the car off and nothing pulling a charge (lights, accessories off).
like the above user said, you should get in the mid-to-high 13V range when the car is running and the alternator is functioning properly and charging the battery.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 10-04-2011, 02:15 PM   #4 (permalink)
88 All-Trac
empersons's Avatar
Response to Charlie:
When i leave my car at idle for a 10 minutes or so, the car eventually dies. You can hear it start to die then it stops completely. The alternator is new too.
I did check the battery volts with the car running, getting 12.21-12.26V
Eric
1988 Camry All-Trac
Pictures
Old 10-04-2011, 03:12 PM   #5 (permalink)
white90dx's Avatar
Ok, so the alternator isn't charging the battery. Put a charger on there (if you have one) and don't drive the car until you get it fixed.
Get the alternator checked, and check all the fuses including the fusible links by the battery. Any warning lights on the dash?
-Charlie
Old 10-04-2011, 03:17 PM   #6 (permalink)
88 All-Trac
empersons's Avatar
-Charlie
I do have a charger so i will try that. I checked the fuses and replaced the fusibles links (all three on the battery). When the idle gets rough before it dies the charge light on the dash comes on.
Eric
1988 Camry All-Trac
Pictures
Old 10-04-2011, 09:13 PM   #7 (permalink)
88 All-Trac
empersons's Avatar
Confirmed the "new" alternator is bad. Hopefully is it was bad when I bought it and there isn't a short somewhere.
Eric
1988 Camry All-Trac
Pictures
