88 Camry compounded starter problem!
Posted before on my 88 4 cyl 5 speed possible ring gear starter not engaging problem until I rocked the car about two inches while in gear (with the key in the OFF position - had to jump in once as it started right up on an slight incline!).
Today, tturn key and just a slight click, no starter. roll started and starts right up.
Tried the tap method on the staretr, worked four times, then nothing.
With the five speed, clutch switch, can put it in neutral, disconnect the spade terminal on the starter and run a hot wire from the pos batt terminal to this connection to check the solenoid and starter?
Battery is good 12.4 v (new), cleaned terminals etc.
So running a hot wire from the battery should energize correct?
Pulling everything tomorrow and ordering ring gear'
Tom
77 F350
77 F150 Ranger XLT
86 Jaguar XJ6
88 Toyota Camry Wagon
91 Mercedes 300 TE 4matic
