Voltage to ground? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2011, 03:45 PM   #1 (permalink)
88 All-Trac
empersons's Avatar
View empersons's Photo Gallery
2nd Generation Voltage to ground?
I am trying to diagnose an electrical short in my car, I assume its a short anyway. With the positive cable connected to the battery and the negative disconnected, I measure the volts between the negative on the battery and the cars ground and get 12.3 volts, give or take a tenth. I assume it should be zero unless there is a short somewhere.
Anyone understand electrical that can help me with this?
Eric
1988 Camry All-Trac
Pictures
empersons is offline   Reply With Quote
Old 10-07-2011, 06:16 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
It won't be zero unless absolutely nothing is drawing power. For example the clock and the stereo are always drawing power, so there is a completed circuit and you will get a ~12volt reading.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 10-10-2011, 11:46 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Sounds like a misunderstanding to me.
If the battery ground and the car aren't electrically connected, then they won't be at the same voltage. In this case, the battery is doing its job and keeps the negative terminal 12.3V below the positive terminal (really, it should be closer to 12.6V - your battery may be low or not being charged). Everything else in the car is sitting at the positive battery voltage because there is no way for current to get back to the negative battery terminal, and thus it stays at the positive battery voltage.
-Charlie
