Last week I noticed an odd noise while driving on 40 mph; it sounded somehow similar to the exhaust roar.
I performed several tests and noted that:
- The noise was speed-related
- I noticed it under acceleration, cruise, float and coast (that ruled out the transaxle final drive)
- It did not change when I shifted to neutral and even switched an engine off (ruled out engine and A/T)
- There were neither unusual play nor abnormal hub temperature
The noise was not evident when I spinned the front wheels by hand (one wheel at the time in the air, A/T in neutral)
"Lane change" test did not change noise.
The only one test that worked was the running car in drive with one wheel in the air and another on the ground; this identified the problem:
http://youtu.be/UBaX_HEOqIE
After replacing the steering knuckle with one from wrecking yard,
I took the bad one apart and noticed a single "pit spot" on the outer bearing race, picture below
According to our machine shop expert, it happened due to material defect, not the bearing abuse
The hub cross-section ( I lost my drafting skills over the time
shows why it is important to properly torque the axle nut to 137 lb X ft on Camry
tightening the nut too much or with an impact wrench can jam the balls due to split inner bearing race (Gap B).
