Some of them simply have the shim sort of built into the pad. Materials have come a long way in the 20 years since our rigs were designed and built.
I installed ceramic pads with no anti-squeal grease or shims on all four corners of the 2wd and it has no squeaks or squeals 3k later. As I recall, the Advance Auto pads need the grease.
I don't see why so many people insist on the shims- maybe it's my young age? I don't know. I simply follow the directions on the box and have quiet brakes. My brother bought some basic pads from O'Reilly Auto and those did require shims- they came with them. This was about a year ago.
I often apply anti-squeal compound to every moving part of the caliper that doesn't come into contact with the pads- as well as on the bolts/pins.
Edit: I have noticed that if the pad springs are missing, the brakes will squeal. Rockauto has the springs for sale for some $1.50/pair. Good deal to quiet some squealing. My brother's Celica lost a spring in the rear and the disc has warped; I'm not sure if these are related but I could see a dragging pad being a bad deal.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
