Right Front CV Axle from Transmission to Rotor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2011, 05:59 AM   #1 (permalink)
1991 Toyota Camry
View karting007's Photo Gallery
I have been looking for replacement parts on my 1991 Toyota Camry LE 2.5L V-6. I am looking for cv axle replacement on the passengers side of the car. I have found the CV Axle at a local auto parts store but it is only the cv axle. It does not include the shaft that actually goes into the transmission and has a bearing installed on it. Does anybody know where to get a replacement for the transaxle between the cv axle and the transmission? Please let me know. Toyota has a new one piece but it is priced at over $500. Let me know. Thanks!
karting007 is offline   Reply With Quote
Old 10-18-2011, 12:09 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Why are looking to replace the carrier bearing? I checked several places and none of them have it, probably because it is rarely if ever replaced.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
karting007 (10-19-2011)
Old 10-18-2011, 12:15 PM   #3 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
That "inner" shaft, if you will, does not need to be replaced unless that bearing is failing- which really isn't too terribly likely seeing as it doesn't take much of a load.
Just replace the outer- you will be good to go. If you really need to replace the whole thing, you could probably find a one-piece on RockAuto but I am of the opinion that the bolt-on axles are better... Easier to replace, anyway.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 10-18-2011, 12:42 PM   #4 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
when i purchased cv axles from rockauto, the passenger side was complete and bolt-up ready. it had everything, the full axle plus the carrier bearing that is pressed onto the axle. obviously, it was significantly longer than the driver's side one.
of course, getting the old carrier bearing out of the mounting bracket was a royal b**ch.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 10-18-2011, 05:31 PM   #5 (permalink)
Mine just slid right out of the bracket- I undid every bolt on the damn thing and then just pried on the old shaft where it went into the differential- the whole shaft and bearing just went "pop!" and came out. Slid the new one in and put the bolts back in. Works great.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 10-18-2011, 05:58 PM   #6 (permalink)
View socal88camry's Photo Gallery
just replaced mine cv and it was a bolt on. I replaced the joint at the wheel and no more clicking noise. 70 bucks at pepboys
socal88camry is offline   Reply With Quote
Old 10-19-2011, 05:15 AM   #7 (permalink)
1991 Toyota Camry
The bearing appears to be bad. It barely turns at all. I have the old shaft and it is alright. I could replace the bearing if that is even possible.
