1990 Camry Squaling on Accel in Park - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2011, 09:43 AM   #1 (permalink)
View Warwick1's Photo Gallery
I need help!
I drive a 1990 Camry 4cyl with 275xxx miles on it. automatic.
Recently on the way home from a 40 min drive, i noticed my car lost all power on accel. I heard a blowing sound and found that I had to replace the vacuum tube from EGR valve to EGR vacuum. I replaced that, blowing noise went away but now I hear squealing noise when I depress accellerator. At idle, car sounds great. WHen I give it gas, i hear a squealing noise that continues as long as gas is depressed. It seems like it's coming from the engine. I can limp it around but traffic is passing by while I feel like a dumbass. At this point I have near zero accelleration (although i hear revving and rpms increase) and can barely make it up any sort of hill. The sound ONLY occurs when i give it gas...and again, I have near zero power and accelleration. I have done some research, cat convertor maybe? belt tension? clogged fuel filter? timing belt?
ideas and diagnostics?
Warwick1 is offline   Reply With Quote
Old 10-25-2011, 04:41 PM   #2 (permalink)
Liscensed Ziptie Mechanic
View gtsrichard's Photo Gallery
RE:1990 Camry Squaling on Accel in Park
So, is the engine is revving appropriately while in gear, and you're just not accelerating? or does the engine feel/sound stifled? IF, the rpms increase like they should normally and you are just not accellerating normally, then you make have tranny issues (is it a manual trans? clutch worn?)
But if you are experincing slow acceleration, and bogging (kinda feels like the car weighs a million pounds) then i would consider, vacuum line loose/cracked, fuel filter, cat converter, and sometimes even ignition (plug wires cracked and jumping fire) issues can produce these symptoms. is the check engine light on?
gtsrichard is offline   Reply With Quote
