'91 base model has no tail light failure sensor! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2011, 09:06 PM   #1 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
I was going to pull the tail light failure sensor out of my '91 2wd to put in the All-Trac... Only to discover it doesn't have one!
http://i177.photobucket.com/albums/w...-01_104613.jpg
http://i177.photobucket.com/albums/w...-01_104618.jpg
http://i177.photobucket.com/albums/w...-01_104637.jpg
I'm tempted to use it as a template to do a bypass on the All-Trac so I can do a writeup.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is offline   Reply With Quote
Old 11-02-2011, 11:25 AM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You should be able to bypass it very easily...
Leave open:
Y-G (yellow, green tracer)
Y (yellow, no tracer)
W-B (White, black tracer)
Connect together:
G (green no tracer) with LG (light green, no tracer)
G-W (green, white tracer) with G-R (green with red tracer)
Before you do that, verify that there are only 7 wires going to the plug - let me know if I missed anything and I'll look at the diagrams again (I'm away from my car at the moment so I can't check). Use a good solder connection, because your rear marker and brake lights depend on it.
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
'88 All-Trac (11-02-2011)
Old 11-02-2011, 02:45 PM   #3 (permalink)
...Well, you've certainly made things easy. I don't know where the heatshrink is, though, so... Well, I don't have to leave for class for more than 2 hours so I should probably go find it.
Thanks a bunch, Charlie!
Edit: And yeah, there are only 7. I remember thinking that was really weird when I was fixing my little box.
Edit numbah 2!!: Brake pedal still lights up my tail lights, turning on my headlights still lights up the brake lights. Is there a secret to a rear light conversion? I updated the rear end to late-model Camry tail lights, could that have something to do with the weird lights? With the stock lights, I got the tal light failure light but nothing was actually broken. Maybe bad grounds? Ah, the joys of a second- or third-hand car.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 11-02-2011, 06:22 PM   #4 (permalink)
white90dx's Avatar
I would assume a bad ground...
I converted my '89 Alltrac to the '91 style tail lights with no modifications and no problems. The plugs are the same, etc.
Are any of the lights brighter/dimmer in each operating mode? (lights only, brakes only, brakes and lights) That would help diagnose which ground you should look at.
-Charlie
Old 11-02-2011, 06:44 PM   #5 (permalink)
-Charlie
Well, I found the issue. When I installed the replacement lights, I only checked the bulbs for soundness of the filaments- the running light and the turn/brake (I might have that backwards) were in the wrong sockets in the driver's-side tal light. The single-filament bulb was causing a short between the regularly isolated circuits. Been chasing this issue for months!
All of the lights got brighter/dimmer with the brake pedal depressed, btw.
Moral of this story? Be sure your bulbs are installed properly!
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
Old 11-02-2011, 06:48 PM   #6 (permalink)
white90dx's Avatar
Lol... yeah, well... the dual filament bulbs have non-symetric locking bumps that should have made it hard to swap them...
Glad you got it figured out.
-Charlie
Old 11-03-2011, 12:48 AM   #7 (permalink)
Yeah, that's why I didn't think to check that. I replaced a bulb on the other side and saw that it was asymmetrical. I had kinda figured that whoever owned the Camry my tail lights came off of wouldn't have made such a cracked out mistake. Perhaps that's why it was in the yard- there wasn't anything else wrong with that particular car that I could see.
It almost sickens me, how many cherry Gen 2s I see in the yard. I don't know that I've ever seen one that had any real damage.
I even saw a near cherry All-Trac that just needed a driver's door go through the yard... I would have snagged it if I had a way to get it home at the time. Real heartbreaker, that one was.
'92 Geo Tracker 4x4
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
