es250 Cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2011, 09:54 PM   #1 (permalink)
[Pro Snow Drift Hoonigan]
TurboATM's Avatar
View TurboATM's Photo Gallery
es250 Cluster
Im curious...and the search seems to not be working right now...is the gauge cluster from the es250 able to be swapped into the Camry dash, just plug and play? It looks quite better, and ive come across one!
1990 Camry All-Trac
1991 Eagle Talon TSi AWD
1997 Eagle Talon TSi
2010 Nissan Versa
TurboATM is offline   Reply With Quote
Old 11-09-2011, 03:26 AM   #2 (permalink)
Is Raaadd
View Bee-Rad's Photo Gallery
It will, except it will only be accurate with a V6 Camry since the tachometer will give different readings from a 4cyl. engine. I want to put the Camry digital cluster in my ES, but it was only available on 4cyl LE's and I will encounter a similar issue if I find one.
1991 Lexus ES250
Bee-Rad is offline   Reply With Quote
Old 11-09-2011, 09:56 AM   #3 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
Don't know if it's similar but if you do a search on here or yotatech you will find how guys swap the 90-95 4runner v6 gauge cluster into a 4cyl. 22RE 89-95 pickup. You adjust the tachometer reading by some screw that guys just barely move to adjust. I don't remember how they get it adjusted correctly...either another tach or someone did a calculation that would get them close and then testing something....I don't remember go search if you're interested.
I did the swap to my pickup but the guy I bought it off of had already adjusted it to the 22RE so didn't have to mess with anything.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
