Engine swap: which is easier to pull engine alone or engine with tranny - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2011, 12:05 AM   #1 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Question Engine swap: which is easier to pull engine alone or engine with tranny
Ok, first of all I've pulled the engine and tranny as a complete unit before so I know how to do this. But I have never separated the engine from the tranny while they are both still in the car. I want to hear the opinions of those of you who have done it both ways and which you consider easier before I do my next swap. This will be on my 88 Camry Wagon with the 3sfe.
I will also be doing an engine swap on my AllTrac, and I seem to remember someone posting the engine is easier to remove from the bottom in the AllTrac. I know Charlie has done that one from the top though.
Thanks All!
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 11-10-2011, 02:40 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
If you are removing the engine, do it as a unit with the trans. If you are doing just the trans, it is your choice (FWD only). Going out the top is easiest in the home garage.
Alltrac, you much do the engine/trans as a unit as they cannot be separated in the car. You can't get it out the top unless you remove the tail shaft of the transfer case. I would suggest going out the bottom. Get nice strong chains when you lift the chassis...
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
es250nut (11-11-2011)
Old 11-11-2011, 10:28 AM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
After pondering it over for a couple of days and looking at the logistics of trying to separate the two while in the car, I do have to concur that pulling the two out as a unit ends up looking like the best option. Even though I only need the engine out.
