1991 Camry LE V6 Engine Transmission reinstall - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2011, 12:51 PM   #1 (permalink)
1991 Toyota Camry
View karting007's Photo Gallery
I have two connections points, one is by the battery and has one connection point, the connector is round with what appears to be a slot for a wire to connect. The wire coming to the connector is white if that helps. Also I have a connection point coming out of the main wiring harness with what appears to be a two pin connector. It is located just above the distributor cap, I can not find a home for this connector, please help if you can. Thanks
karting007 is offline   Reply With Quote
Old 11-12-2011, 01:28 PM   #2 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Diagnostic test point for shop troubleshooting.
On my 4clyinder I believe this particular wire was connected to the transmission/motor mount?
Not sure on the V6
Sturdavj is offline   Reply With Quote
Old 11-12-2011, 01:52 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Not sure about your first question, the second question, is this the connector? If so, nothing plugs into it.
Here is a complete engine bay in case you need a reference.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 11-12-2011, 02:34 PM   #4 (permalink)
1991 Toyota Camry
Here are the Pictures of the connecctors
Here are the pictures of the two connectors, the round one is by the battery and fuse box. The second is located on top of the distributor cap and below where the air filter attaches to the plenom.
Old 11-13-2011, 01:57 AM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Can you name the wire colors for the wires on each connector? That will help find them on the diagrams.
-Charlie
Old 11-13-2011, 05:24 AM   #6 (permalink)
1991 Toyota Camry
Wires
The round connector has a white wire with a green strip. I will check the other connector. Thanks for your help.
Old 11-13-2011, 09:18 AM   #7 (permalink)
1991 Toyota Camry
Two Wire Connector
The two wire connector has a brown and gray wire.
Old 11-13-2011, 01:40 PM   #8 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Brown & gray is probably for EGR thermo sensor in the EGR valve (lower photo)
On upper photo the cylindrical single wire plastic connector (C3) is for All-track and may not be needed
Doctor J is offline   Reply With Quote
Old 11-14-2011, 05:01 AM   #9 (permalink)
1991 Toyota Camry
Doctor J, I went out last night and searched everywhere around the Egr Valve and found no place for this connector to connect too. Can you send me a photo of where you think it attaches? Thanks in advance!
Old 11-14-2011, 08:15 AM   #10 (permalink)
Doctor J's Avatar
It used on 89 California and 90-91 federal(?), 4 and 6 cylinders. The sensor is threaded into the EGR valve right under its "hat"(4cyl) or into the plenum(6cyl). your engine may just have a plug in the plenum as on picture above by Corolla71
Old 11-14-2011, 12:09 PM   #11 (permalink)
white90dx's Avatar
Based on what I've seen... both are left open on your car. (one is for EGR gas temp which you don't have and one is for ABS which you don't have)
Also, if you look closely at the pictures, you can see the built-up grime inside the connectors where they would be clean if they were plugged into something.
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
karting007 (11-14-2011)
