Guys.
I wanted to get on today and say THANK YOU VERY MUCH to the folks at Toyota Nation. As some of you are aware I have been working on a 1991 Camry LE V6 for about 6 weeks. I had to change out a transmission which included a motor pull, change the transmission, and from advice on here I also changed the water pump, thermostat, cam seals, timing belt, front and rear crank seals, valve cover gaskets, transmission gasket, transmission filter, distributar cap, rotor, plug wires, plugs, pcv valve, timing belt tensioner, cv axles (both sides), brake calipers, brake pads, etc, I will say I am not a mechanic, I had alot of questions along the way which were answered by a great group of guys. I want to say, this is a great site with great people and I am very proud to be a part of Toyota Nation!
I had alot of questions along the way and folks on this site answered the questions in a quick timely manner. The car was drivin to work today by my son today and it is running better than it has in a long long time!! So thanks goes out to Sturdavj, 71 Corolla, White90dx, Doctor J, atobe, 88 All-Trac, nitronate33, socal88camry and Grego92.
I also need to thank my good friend Andy. He has been a great help during this process.
Thanks to you all, if there is anything I can ever do for you please do not hesitate to ask!! Thanks again.
Tony Fields
